DaChLi
- 0
- 0
- South East Pennsylvania
Picked up my set from Ft. Meade and like others have water in exhaust. I used a shop vac and sucked it out of muffler, removed muffler and exhaust manifold and sucked it out of the exhaust ports in the head. I then put a socket on the crank pully and the engine does rotate. What does anyone think about pouring atf thru exhaust ports at this point as the engine does turn? Would it still remove any corrosion or contaminants? Is it better to atf thru the injector ports? Does fluid normally flow so much inside the head? I imagine residual atf would burn off inside the head when the engine is running? Also, if i remove an injector would an inspection camera be able to view the inside of the cylinder. I imagine the passageway is too small. I'm trying to see what's inside without pulling the head. So far i feel lucky, all the panels are there, the engine turns over, and all the components appear to be there minus the battery trays and hold downs and secondary fuel housing(which i believe i found on ebay). Thanks for helping a beginner....
