MDM1008
- 0
- 0
- mt airy md
I am new to CUCV's, please bear with me.
Just bought a M1008 from a guy who did a bunch of "work" on it. He installed an electric fuel pump and bypassed the mechanical pump. My questions are as follows:
-Should I remove the mechanical pump? Would I need a block off plate?
-Should I remove the pushrod? and use the old pump as a block off plate
-Do I need a pressure regulator or relief valve on the fuel line? ( no idea what psi the pump is putting out. how much pressure is too much? )
-I can find a block off plate locally for a small block chevy, but nothing else. will it fit?
Thanks for any and all help.
