70deuce
- 121
- 43
- Franktown, CO
Didn't want to pay for a new shutter stat so I installed my manual fan actuation mod. Spent about $25 on the parts and now have complete control of the engine fan from the cab. Got a dual purpose switch from Erik's Surplus. It is an air switch and an single pole electric switch. The air side bleeds off pressure when turned off so its perfect for the fan clutch. Fan disengages within 5 seconds when switched is placed to the off position. Plugged the shutter stat tap on the crossover pipe. I joined the two lines in the engine bay together and used 1/4 inch push lock connectors and 1/4 inch black air line to run in to the cab and the switch. I used two 90's at one connection because I had those parts. A straight connection will work fine. I wired an aircraft post warning/status light to the electric side and it just happened to be blue. I will try to find some white dry transfer lettering to label it "engine fan". I just monitor the engine temp regularly which I do anyways and as it approaches 200 degrees I turn the fan on. When it drops below 185 I turn it off. You don't need the fan very often when driving. These engines run fairly cool while in motion. Running the PTO driven gear static and in parades you sure do. Another bonus of this set up I can turn the fan on for the 5 minute cool down period before shutdown. That noticeably cools it down before the engine is shutdown. I will put a parts list together shortly. Also I found I nice looking Cummins badge that uses good 3M double sided tape to attach it. Seems to be stuck on there good.
