- 2,481
- Columbus, Georgia
OK, I won't send the remote but I WILL be monitoring the cameras closely and if Zout is not a good troop then: EL ZAPPO!!
These trucks were specially designed with snubbed noses so the operator could drive up close to a building and the enemy would fly over and think the signal truck was part of the building or just a storage shed.Even after all of the previous pictures it was not until the last three that I noticed that the K18 had been punched in the nose.
It has not been punched in the nose. The K18 is part of the "Pug" series of MV.![]()
Apparently the electrical box in the garage is more than he can handle.Is there ANYTHING you can't get done??
I've seen that box and setup several times. Looks just fine to me. Besides...it was easy for me to tie my cameras and zapper into.Apparently the electrical box in the garage is more than he can handle.![]()
Sounds like you had a rather shocking experience!Ask Deb about me getting electricuted years ago and it was not a laughing matter - I was told after a few seconds it should have killed me - there is more to what happened so just ask me at the cookout. But the wiring stays like it is.
See that yellow strap - I towed that long piece home from work - just dragged it on the streets - I did not want to scratch up my pretty new used truck bed.
Correct! I had to send him "a little reminder charge" early this evening!I trust youre not letting Zout anywhere near the rig until until said time he is allowed to resume work.
Been known to happen.the zapper MAY have been turned a little TOO high...and things got a little messy.
Horse poop!! You know I'm computer challenged and it takes me two days to post a pic!!I made a firm promise to my FRIEND and there is no deviation in mind - plain and simple.
Been getting stuff off the chore list for the cookout done and the list is not a pleasant one. A few have heard of some of the results of trying to rush through that list which caused more work.
Been hunting down window channel seals for the box sides - been hunting down RARE dual pane window channel rubber for the rear glass
Been hunting down windshield crank out seals and crank out rebuild kit for the mechanism that is stripped out as well.
Only some of the glass gets loaded up and start working on getting sections of this cut - still need to tear apart framework for the rear box roll up windows but read the first sentence of why this is not happening yet.
If in doubt that I am slacking - go back and read the first sentence again. COOKOUT COMES FIRST at this point in time. Those coming will see it as it is - if Skype is on you get to see it as well.
All I can tell you is after the cookout is done - Do Not Blink - Do Not turn your head to look away - there are some good things to come.
FedX from what I was advised today is delivering the TM Ordinance #8 paint TOMORROW and enough for one of PB's other projects he has in mind (and that Is non of my business) But he can pick up the paint at the cookout.
Hang in there and I just may send PB pics as this continues as I do not want SS site to be a restoration forum or turn threads into restoration forums. Its his decision whether to post pics sent to him from this point on just so those watching know what is going on. There will be no more posts as to what is happening from me - but is what is currently happening.
Hang in till after the cookout.
