TacticalDoc
- 26
- 18
- Otisville MI
UPDATE Trans over pressure Issue Explain TM Replenishing Trans Oil procedure for M923
Procedure from the TM
1 Add trans fluid and replace dip stick
2 Start engine until reaching normal operating temp then SHUT OFF engine
Note
Begin shifting trans through driving ranges only after normal operating temp is reached
Preform shifting procedure for 2 min before returning to neutral and SHUTTING OFF engine
3 shift trans through driving ranges to allow oil to circulate
4 check level and fill as needed
Ok ...I have no clue when to start and stop the motor and when to shift trans. Please explain
I'm assuming you add fluid, warm it up, shift gears for 2 min then shut it off and check level. But, the dipstick says check while idling and in neutral.
Note
