Reaper651
- 1
- 0
- Menifee, California
Hey All,
Well, I finally got my truck! Its now at its temporary home about 45 minutes from my house. It hadn't ran in 7 years and it fired right up for me to load it on the trailer. It does have a couple issues, all gages with electric senders don't work, headlights work but no other lights do, the alternator isn't charging, it needs new seat cushions etc. Nothing too serious. The only problem that has me a little nervous is it does not want to idle. It tries to idle, RPM surges a few times then dies. If you use the hand throttle to hold the idle up a bit it stays running. I only drove it a tiny bit, (I know but I couldn't help myself) but I also noticed that upon giving it throttle just after a shift, there is also a short lag time in the RPM coming up. The fuel in the tank smells a little old but looks clean and the electric pump is working. I know I need to change the fuel filters and get fresh fuel in the tank before even considering anything else, but if that doesn't fix it is there anything else to consider before diving into the IP? I was also wondering if the FDC could cause this problem? There are a few good threads on this problem but they all seem to point at the hydraulic Head aside from the obvious issues of dirty fuel filters, fuel leaks etc. Might anyone have any tricks or things to look at? Aside from this issue, the engine seems to run great and has good power. I might be getting ahead of myself by asking such questions before changing fuel filters and fuel, but I figure its worth being prepared for the worst. I'm also hoping that the little drive I took didn't hurt anything, as I only drove it about a quarter of a mile and I must say, it was an awesome feeling sitting behind the wheel of this fine piece of green Iron. Thanks in advance.
