aheilmann68
- 1
- 18
- North NJ
Trailer is half decked with 2x6 Oak. Still debating on whether or not to do the entire deck as it worked out well open in the middle. Tie down points are going to be welded it, we just wrapped cross members and the trailer tie down locations. The deuce weighs 11,500lbs and the winch pulled it up well, had full control and the remote function is great. Trailer sways a bit with the drainage basins but the air ride does a pretty good job of keeping it from going all over. Overall this trailer is great, we had the deuce on the trailer at the Sussex MTA show and set up a display that I will try to locate pictures for, since I was running around all weekend.
I have a Perkin IOM manual for the 400 series motors that I will have to put up later
As for the protective covers, they were removed and the rusty screws were no match for an air chisel. I am not sure if the sensors even work because I tested to see it the bed will try to raise even with the latches on and it does try to. I don't think the guides are going to be carried on the trailer as I do not see the trailers owner moving conex boxes, just equipment and vehicles.
![NCM_0250.jpg NCM_0250.jpg](https://www.steelsoldiers.com/data/attachments/334/334398-77d7a2ffff76b647e1d7ae1fc7841b13.jpg)
![NCM_0241.jpg NCM_0241.jpg](https://www.steelsoldiers.com/data/attachments/334/334397-ee6e3721f9315dc40357e41704cfc28f.jpg)
![NCM_0251.jpg NCM_0251.jpg](https://www.steelsoldiers.com/data/attachments/334/334399-46f5a646056b256ced8ca6ddc1949569.jpg)
