swindad2
- 0
- 16
- Franklin, KY
So I decided to let my local machine shop tackle my air pack rebuild. I know, should have done it myself, but the combination of my health, work space, and too many other projects made the decision for me. So they called me and said a part was missing from the rebuild kit, to come and look at it. I agreed that it was not in the kit, but I received the kit, opened, with the truck, so I assumed maybe it was just missing. Ordered another rebuild kit, and it contains the same parts. The part in question looks like a bushing (metal core with rubber surround). It fits over the push rod shaft, inside a smaller housing, at the joint where the two halves of the pump meet. I have read through all the rebuild threads on the site, and looked at the TM/rebuild guide. You can see the part in the diagram, but nowhere does it mention removing or replacing it. It is not numbered in any of the diagrams. I assume since it is a rubber part, over the shaft, that it should be replaced. I have included pics to show what it looks like. It is pretty chewed up. Where am I going to find this thing, or should it have been left alone?
Or is this a combination of two of the seals I'm just not seeing. The metal part is throwing me off. It appeared to have been one part.
Here is the rebuild manual thanks to rustystud: http://www.steelsoldiers.com/showthread.php?118450-Air-Pack-Rebuild-Manual
