gimpyrobb
dumpsterlandingfromorbit!
- 27,791
- 785
- Cincy Ohio
A long long time ago, I bought a multifuel motor from a bud. Since I have owned it, I sold the IP off it along with other parts. Now another bud has a deadlined truck. A couple years ago I installed an LDT IP on this motor to see if it would run - just out of curiosity. Today I put that motor back together to see if I could help out Nathan. The IP I put on today was an LDS IP that came to me out of the box, but supposedly new as it had all its ports plugged. After some time, I was ready to try it out. I started with the "motor shutoff" lever pulled out so the motor would get some oil pumped through her. Then I released the lever to let her start up. Slowly, it chugged to life and for some reason, it seemed to want to run away.
Yes I checked the fuel shutoff lever under the cap to make sure it was free.
I also noticed that I hadn't tightened some of the injector lines in their injectors and some of the return lines were leaking. After I tightened everything up and grabbed "soldier B" I fired it up again. We confirmed it was wanting to run away, but was controllable using the fuel shutoff lever.
It was dark and a long day, so I called it. Tomorrow or Sat I will be pulling the fuel shutoff rod to make sure it is seated correctly in the fuel block cutout. What else should I check while tinkering? Someone mentioned it might be timed too far advance.
This is an LD motor originally, and I installed the IP to be timed with the LDS timing mark. Should I try to set it back to the LD timing mark? The motor does not have a turbo on it now, but will get a turbo before it gets installed in the truck.
Anything else?
Anything else?
