Inexpensive camper/utiliy box for m35a2
desert demon
Tooele Utah
Desert Demon,
Good project you have in mind. The two schools of thought are, (1) drive the camper and tow the gear. (2) drive with the gear and tow the camper. One big advantage of number 2 is when camp has been set up, you still have the truck to use, and won't have to depend on a motorcycle. Both plans work well, just fit them to your needs. P.S. Did you pick up your Deuce Trailer off KLS not long ago. I love those things! Unclemikey.
Thanks Unclemikey.Yes I picked up the trailer on KSL in June or July last summer.It was down in Provo UT.It was a fun trip :naner: My buddy that went with me thought I was :cookoo::cookoo::cookoo: when we brought it via Butterfield/Middle canyon.The switch backs were fun with no brakes.Check out the pics on my profile.
berserker
reading, pa.
Wow! I caught this back when wreckerman893 mentioned metal building panels w/ bubble insulation for strength etc. I went off on a tangent...
http://www.gdatp.com/factsheets/M006_CBC- Type III & IV.pdf Finding this amongst all kinds of articles, personally refraining from a camper due to room.
The premise is wonderful albeit expensive. Also originally approximately five hundred u.s. I believe was mentioned? THAT ain't happening excepting blind luck, extreme salvaging could, hehe.
All the ideas I've seen since catching this today are cool but I personally want all eggs in one basket with option of dropping trailer if necessary. I've opted to use steel roofing going up the sides and over bows gluing one inch polystyrene and gluing another sheet over that.Will be semi- permanent. Ends enclosed in similar manner. The 17 pieces @ 12' 3" of siding cost me 100.00 on sale alone. Glad to see all of us who are afraid of "those" people seem to think alike on a lot of these building ideas!
unclemikey
97
south west
Thanks berserker,
I had not seen that article, way cool. You are right about one thing, the $$$$, I have and will have more than $ 500 in Advil alone. Don't you just love it!.
718
9
Springfield Or
Finished plumbing water heater bypass and installed out door shower. Fired up the pump and watched the water flow. It flowed right onto the ground, still need to plumb in the drains and valves for grey and black water tanks. That will have to wait for dryer weather.IMG_20140331_151408.jpgIMG_20140331_151344.jpgIMG_20140329_135102.jpgIMG_20140329_150425.jpgIMG_20140329_135058.jpgIMG_20140329_160344.jpg
(Prov 3:5-6 [KJV 1611])
Trust in the Lord with all thine heart; and leaue not vnto thine owne vnderstanding.
In all thy wayes acknowledge him, and he shall direct thy pathes.
Translation
NKJV
5 Trust in the LORD with all your heart, And lean not on your own understanding;
6 In all your ways acknowledge Him, And He shall direct your paths.
718
9
Springfield Or
Insulated inside the propane storage and behind the 40 gal. fuel tank.
Cleaned, panted and installed the roof top air. It puts my height at 12' 6"
IMG_20140315_110650.jpgIMG_20140315_110658.jpgIMG_20140315_110708.jpgIMG_20140315_122608.jpgIMG_20140404_102403.jpg
Psalms 1 1-2 1 BLESSED is the man Who walks not in the counsel of the ungodly, Nor stands in the path of sinners, Nor sits in the seat of the scornful;
2 But his delight is in the law of the LORD, And in His law he meditates day and night.
718
9
Springfield Or
Framed in one side of the dining table seat. Installed the 12 volt power supply / battery charger. Finished the propane plumbing and tested the water heater, stove and refrigerator. The heater needs 12 volt power and I am not that far along yet. last time I tried to light the heater I caught myself on fire.
IMG_20140405_134641.jpgIMG_20140405_145146.jpgIMG_20140405_162559.jpgIMG_20140405_145137.jpgIMG_20140405_162549.jpgIMG_20140405_162645.jpgIMG_20140405_153453.jpg
718
9
Springfield Or
Tore out the old upper cabinet. The joist were pulled from the outside wall. Put a ledger under them. It will be hid inside the cabinet.
Also built the other dinette seat and wall behind it. The space behind wall will be for large storage like folding chairs, camp stove and such.
IMG_20140412_164115.jpgIMG_20140416_162149.jpgIMG_20140416_170352.jpgIMG_20140417_162839.jpg
718
9
Springfield Or
Tore out a cabinet and extended the kitchen counter space.
I have some hardwood butcher block flooring that came out of a service van.
I will use it for the counter top. Insulated the wall, pulled in 110 wiring and installed furring strips.
IMG_20140508_103832.jpgIMG_20140508_104636.jpgIMG_20140508_105745.jpgIMG_20140508_132233.jpgIMG_20140508_125731.jpgIMG_20140508_125723.jpgIMG_20140508_144453.jpgIMG_20140508_144438.jpgIMG_20140509_155826.jpg
I should add that God has provided an abundance of free material for this project. From the holding tanks to the rooftop air he has provided it.
I had run out of 1 x stock and it stopped my progress as I had no furring material. That same day as I drove past the busnisse next door there was a stack of 10' long 5' wide palates with ten 10' 1"x4"s on then. The sign said free so I grabbed two of them.
Thank you Yahweh.
9
Springfield Or
Today I put up the Tempered hardboard on the wall over kitchen counter.
I then installed the upper cabinets. I am building them out of scrap plywood. They will be covered with tempered hardboard and painted.
718
9
Springfield Or
Been plugging along. Wrapped the cabinets with Tempered hardboard. Installed the range hood and put on the first coat of paint. Found a color that gives the same feel as Sea Foam Green.
IMG_20140517_163252.jpgIMG_20140517_133648.jpgIMG_20140518_163413.jpgIMG_20140513_144433.jpgIMG_20140513_144428.jpgIMG_20140513_144417.jpg
718
9
Springfield Or
I took some old pallet sleepers and ran them over the Jointer to square two sides. Then ripped them into 2x2" for the bathroom ceiling joist. After installing them I cut in the roof vent and put up the hardboard. This time I primed before I filled the staple holes as I kept missing some until the paint reveled them. Then I climbed on the roof and screwed down the vent.
IMG_20140524_110343.jpgIMG_20140524_110349.jpgIMG_20140524_110334.jpgIMG_20140524_121800.jpgIMG_20140524_125341.jpgIMG_20140524_130753.jpgIMG_20140524_141946.jpgIMG_20140524_160112.jpgIMG_20140524_144228.jpgIMG_20140531_131723.jpg
