ralph3162
- 2
- 0
- Pleasanton / Texas
Well when it rains it pours I guess. I have had a brake problem over the weekend which I have figured out the problem (Air Pack). Then I had an issue figuring out how to replaces the axle seals (thanks for the help). Now this morning without warning or symptoms of any kind my turn signals wont work. Brakes lights, Head lights all other lights work just turn signals and emergency flashers don't work for no apparent reason. I have ordered a new flasher unit and a new turn signal lever, and a new light switch. So as long as its not in the wiring then I should be good but just seems weird I fix one thing and two more stop working. Thankfully I can afford to by parts and replace what's wrong and save the rest for future spares. That being said I like to do preventive repairs. I like to replace things before they go bad so I am looking for suggestions as to what are the most common things that go wrong with 2 1/2 ton green iron so I can get ahead of the curve and fix things before they break. Any suggestions about the usual common problems with these vehicles would be great. Money is not an object I have a great Oil Field job that pays well and I live cheap so I have lots of mad money. Just want to know that I can get in and drive across country if that is what is needed at a moments notice. Thanks for the input.
