Reaper651
- 1
- 0
- Menifee, California
Yes That's what I'm kinda thinking. Oil pressure, water temp, voltage or air pressure and maybe speedo. Maybe not the speedo since its almost impossible to go over the speed limit in the deuce. I'm going to see if Stewart Warner has 24 volt back lit gauges with Packard connectors. I will be surprised if they have Packard connectors but the should have 24 volt. I don't see a point in converting the truck to 12 volt. I will post part numbers when I find them.The only way to go if you really want light on your gauges is to replace all the military gauges and go with civilian ones. As for me, I've replace my oil pressure gauge and I'm thinking about the Voltage and coolant but the rest can stay as they are.
