Can't get the top axel cover to stop leaking?
acme66
9
Plains, Montana
I have been at this plate a few times now, once with straight gasket sealer like I found it and like the other axles. Once where I made up a nice thick cork gasket and sealer on both sides. For the life of me I can't find anything wrong, the cover sits flat, no damage to the sealing surfaces... yet I haven't so much as slowed it down. Each time it was like I had made no change. Doing some reading here I will go and pull the vent and check that it is not plugged but it spins freely and springs back so I bet it is fine. I admit I have not waded through the TM, mostly I figured how complicated can this be? It seems to be leaking from the center of the bracket that supports all the air lines or there about. It isn't that big of deal and stops leaking before (but close to) what I would consider the minimum for rear end fluid level but until then it coats the back of the truck and the stairs in oil. Have I missed something or do I just need to have at it one more time. I could make gaskets from thick and thin gasket paper, thick and thin cork and thick heavy rubber or just RTV from the tube.
Ken
plode
South Jersey
Haven't used it on this truck yet, but in the past I've used Permatex the right stuff gasket maker on differentials. Never had any leaks.
Coffey1
500
Gray Court SC
And just because that cap on that crappie vent moves don't mean anything .
Drive it come home take a wrench and remove it . I did it and there was a great deal of pressure.
So I totally removed mine and run tubing.
I also had a pinion seal leaking put new seal in and it still leaked yet not as bad but totally quit when I got rid of those worthless cap vents.
plode
South Jersey
I want to run tubing from the vents up the back side of the intake stack. What kind of tubing did you run?
Coffey1
500
Gray Court SC
rear axel to middle tee then up to stack area run tubing from front to the rear tubing and tee it to the rears then run tube up to the top of stack then put a charging port in the end of tube removed shader valve .
then if i decide i am going to get into water put shader valve back in and pressurise it to about 6 psi to keep water out of axels
plode
South Jersey
So made your own fording kit for the axles, awesome. I'll likely do something similar.
