Westech
CPL
- 6,104
- 207
- 63
- cow farts, Wisconsin
I don't know about the alternator itself. You could try checking the B+ terminal with the engine running to see if it's charging on the 12 volt side.So if I don't have all 3 hooked up it won't charge?
So I should just get a 12v alternator civy unit ?
Neat back story!I don't know about the alternator itself. You could try checking the B+ terminal with the engine running to see if it's charging on the 12 volt side.
The 12-24n is for charging at 24 volts from a 12 volt alternator. I think the M915A1 is all 12 volts except the starter and the military trailer lights and maybe the blackout lights. I just got mine and haven't got into the electrical system yet. Fortunately it all works, but if my starter ever takes a crap, it's getting replaced with a 12 volt unit.
I worked for Transpo and later WAI for about 16 years as a mechanical designer/engineer. I still have friends that work there and I drop by to visit once in a while. I emailed a EE buddy this morning to ask the details on how the 12-24n works. He said it would work, but his advice was to get an OE because of the low current output. YMMV. Good luck.
