acesneights1
- 21
- 20
- CT
Finally got it on the road, all registered etc. Put about 100 miles on it.
Figured out the lights finally. I wasn't operating them correctly and also found a broken wire on the brake light switch. I re plumbed the switch as it was hitting the drivers side tool box.
Some things, possible issues. Bear in mind, I have never driven one before.
The steering is very difficult. I realize it is not power and at low speeds should be hard but even at highway speed, I need two hands on it. The front axle is out(airshift T/C)
Is this normal or do I have an issue ? I greased the king pins,all shafts and checked all diifs and TC/tranny.
Second it has a vibration from about 30-40 mph. After 40mph it pretty much goes away. My son says he hears a chain jingling noise under it while we are driving. I don't hear anything but my hearing ain't so good...![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
The Vibration is not the motor, it's in the driveline. Almost feels like bad u joint but they all feel fine. Possibly a bad ring gear ??![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
It's not earth shattering but I can feel it.
