Woodsplinter
- 6
- 18
- Phoenix/AZ
I removed the propeller shaft between the transfer case and the front rear differential so I could remove the parking brake shoes. On the end of the tube facing the parking brake drum is a hole.
The TM states that there is supposed to be a "breather" there. Does anyone know what this is and where I can get one. The breather cap that is used on top of the axles would be too tall. The edge of the hole is ragged and I can't tell if it was ever threaded but the TM indicates it was.
Grease has apparently been leaking out of the hole for some time as there is plenty around the parking brake drum shield.
The breather is listed as item 2 in the TM.
Thanks!
View attachment Deuce Propeller Shaft.pdf
Thanks!
![IMG_1398.jpg IMG_1398.jpg](https://www.steelsoldiers.com/data/attachments/343/343791-31961056aa99ae7d921f2242bc3a3c47.jpg)
