- 5,592
- 2,877
- Metairie/La (N'awlins)
Nice radio set up!Let's try this again. 3rd time is the charm right?
View attachment 505386View attachment 505387View attachment 505388View attachment 505389
I tried to use the entire setup but it was like putting a square peg in a round hole since the 809 series bench and transmission hump are different. I could have cut a rewelded but wasn't really in the mood for it.Nice radio set up!
Yeah I saw your thread, just not really wanting to cut a hole in the firewall. I'm going to see if I can squeeze my harm back there before I get the saw out.Dual fuel line is worth it. $40 in parts. And you can feel/tell a difference.
No marine batteries from walmart. For 100 a piece they have done good so far. Bret had to jump me off when I left his place but I figured they would drain down because of my USB charger constantly plugged in.Are those golf cart batteries?
The radio only draws about 30 amps now but I'm going to put a 500 watt amp on it so I need the reserve power for it and for the doh moments when I leave the Vic 1 on or the power switch on.I was kind of wondering why you are going to an eight battery setup. That radio shouldn't draw anywhere near that much power when keyed up. If you are having starting problems you need to find the cause of the drain, not add more batteries.
This amp covers 1.5 - 22 MHz and requires 84 amps at 14 v to power it at full power.You are going way overkill man. I used to run a 2500w box driven by my 10m Magnum S-9 and only had two 1000cca group 31s and a 100 amp alternator with a 10 farad capacitor inline. Talk about shutting down a truckstop.
It has 5 2SC2879A transistors that each has a collector current of 25 amps. For what it does it is actually very efficient. It has a power draw of 40 amps on SSB, an 80-90 on CW.And 84 amps at only 500 watts is terribly inefficient. Most comparable amps like RMItaly and Palomar products only draw around 30 amps at the same output, and have quite a lot of modulation if driven properly to boot.
