The Freightliner series provides lots of opportunities for neat little upgrades. Thought I would show some from over the past year and hopefully encourage others to post what they have developed.
Sliding rear cab window--standard on the M916, but not on the A1. Needed to keep the air moving through the cab. Good suppliers in the construction equipment market will make them for reasonable costs, to your spec, without the nonmilitary RV fittings and finish.
![IMG_2103.jpg IMG_2103.jpg](https://www.steelsoldiers.com/data/attachments/344/344158-2ed80e680c4fdae8e508847338e865f4.jpg)
Work Lights - Originals are not so tough plastic models. Substituted military wrecker lights for better performance and looks.
![IMG_2106.jpg IMG_2106.jpg](https://www.steelsoldiers.com/data/attachments/344/344159-297707870c6cbaf70adc746d7984af8a.jpg)
Pioneer tools- no provision on the A1. Adopted the location for the rack from the 10 ton M123 tractor where it is on top of the tool box.
Water can - also good idea, fits into the decon mounting bracket.
Tail Lights- latest models, 916A3, use the composite LED lighting. Easy substitution, with the backup light to follow soon.
![IMG_2108.jpg IMG_2108.jpg](https://www.steelsoldiers.com/data/attachments/344/344162-63397a8c625d26634366460d05d934ce.jpg)
Power outlets in the cab - nothing supplied but 12 and 24 needed for accessories. Added on the solar charger kit with roof mount for the large panel, and behind the drivers seat for the distribution box and the battery condition indicator. Puts the units close to the battery box for short leads, and supplies all the fused power sources you could want inside.
![IMG_2101.jpg IMG_2101.jpg](https://www.steelsoldiers.com/data/attachments/344/344163-a6b3804b0ec0c8293bcad6e3251e681a.jpg)
Antenna Base - many possibilities, one spot is on the hydraulic tower, allowing good motion for the whip, and a secure mount.
![IMG_2143.jpg IMG_2143.jpg](https://www.steelsoldiers.com/data/attachments/344/344164-e7d76db64fb6487d0ca44df4290dfa6b.jpg)
![IMG_2145.jpg IMG_2145.jpg](https://www.steelsoldiers.com/data/attachments/344/344165-79a5dcc61a00dcaf846df7433d6b39a7.jpg)
Storage boxes - lots available on the A1. The SS classifieds provide keyed alike locks, manual calls for 7 of them.
![IMG_2146.jpg IMG_2146.jpg](https://www.steelsoldiers.com/data/attachments/344/344166-67e11a48fcb2e65ee8be9be2335a186f.jpg)
Add-on Hydraulic controls - the transfer shift tower provides great spot to anchor any remote cable levers. Short run to under cab floor, making it easy to keep oil out of the cab.
![IMG_2100.jpg IMG_2100.jpg](https://www.steelsoldiers.com/data/attachments/333/333085-5be548c8b530ac7a68f9f1981188c516.jpg)
Lots more ideas out there...let's see them!
John
![IMG_2107.jpg IMG_2107.jpg](https://www.steelsoldiers.com/data/attachments/344/344160-e8f76926c59e602b141a0aa895e5e553.jpg)
John
