tim292stro
- 41
- 48
- S.F. Bay Area/California
If you want to allow your wife to be able to drive it - teach her to drive stick!! (J/K).
You might look at the Allison 1000 and 2000 series automatic transmissions. They use these behind Duramax GM diesels now, and if you get a 2006+ version you can have a >750-ftlb input torque rating. It can use an SAE #3 flywheel housing, so it shouldn't require too much firewall surgery.
As for the transfer case, you might consider a doubler in front of your NP205 - the most common match up is an NP203 range box (not the crappy 2WD/4WD transfer function). The NP203 will give you 2:1 or 1:1, and the NP205 gives you 1.96:1 ad 1:1. Combined it gives you 3.92:1 total low-low, 1.96:1 in high-low, and a 1:1 high-high - all before the NP205 2WD/4WD transfer gears. More options and better control - I've also seen this setup adapted to an Allison auto (2400) - also because you only use the gear selection of the NP203, it doesn't add a lot of length to the t-case.
Make sure whatever spray on noise blocker material you use, that it is a vapor barrier. Also have good paint under the coating, and then paint over it again. You don't want to do primer, then a waterproof but vapor permeable sound coating and no top coat "seal" - if this isn't done "liquid water" will splash off the sound coat, but water vapor will pass through, and since primer is very porous water vapor will actually find its way down to the steel - and rust your truck's skin from the inside out. The other part of the sound equation, is taking care in not generating it - rather than beating it into submission with sound deadening .
