Official 2014 SS Ga. Rally buy/sell/trade thread
1,165
1,165
I will be arriving on Wednesday and leaving Sunday.
I am looking for the following items:
M35A3 shoulder belt seat belt system for driver and passenger seats
Overdrive unit for GPW/MB (18 series transfer)
Bolt for M44 series winch rope termination (this is the bolt that secures the chain to the rope termination)
I am selling the following items:
Several nice deuces, with winches, all service done, etc. PM for details.
Looking to trade:
I'd like 11 new 11:00x20 radials but I don't have the money. Do you have such tires (Michelin XL, Firestone T831, Goodyear G177) and you need something I may have or want to trade some labor for said tires? Inquire via pm.
gimpyrobb
dumpsterlandingfromorbit!
27,791
791
Cincy Ohio
I have pallets of new deuce fiberglass headboards. $50 each
I have had folks ask, yes they are the same width for a 5ton, but you'll need to modify it a little.
I also have stock troop seats for the M342 deuce dump truck, I think those are $50 each
I have a TON of m101 trailer tailgate racks, but they are the driver's side only. $10 each
I have a bunch of fiberglass material if you need to replace rotted wood or broken glass, but they are only 10ft long, not 12ft like whats on a deuce. It can be easily spliced though.
I'll have my Stanadyne FM100 filter setups that many have put on cucvs and gen sets.
I'll probably bring my flood lights too.
If I have something you want and it isn't listed, I can probably bring it too.
MWMULES
352
DESOTO, KANSAS
To help gimp out I have a bunch of the pass side 101 gates with wood that needs replaced for $5ea. All you would have to do is a little transplant surgery to have a nice set of gates. PM me if you want one as as I won't be bringing them if they don't have a new home.
5,221
As of right now, I know I'll have the following:
M939 series heater $75
M939 series map box $25
M939 series gauge pod with speedo $25
Various other M939 series nick nacks
M35A2 Heater setup
and I'll find more stuff I'm sure.
1958 M274
North GA
I'll be there Thursday through Sunday. I have two replica M16A2 rifles (The A1s in the picture have been sold) and 5 Titan 11.00-20 NDCC Tires. Four of the tires were run for about 300 miles before switching to radials. The fifth is a good take off with about 75% tread. Some have tubes and flaps. $315 each or $600 for the pair of dummy M16A2s. $110 each on the like new tires, $75 on the 75% tread, or $425 for all five tires. The tires have been stored out of the weather under a shed. They were just rolled out for the pictures.
EMD567
Driver for the Ga Mafia
Aiken SC
I need two complete 5 ton fuel tanks-Frame mounts, straps and tank off a 900 series cargo truck. This is the 81 gallon tank on the 923, 925, 927, and 928. If you are in the SE, I might even come before the rally and pickup.
I would like then to be dent free, and color doesn't matter.
rebelqwes87
Loganville, Ga
I will be bringing:
(1) M35A2 Grille $40
(4) M35A2 Wheels $25 ea.
(2) M35A3(I think) Inner Beadlocks $10 ea.
(4) M35A3 CTIS wheel parts and pieces, basically everything mounted on the wheel $40 for all pieces
(1) T bar handle/latch for the 939 series truck w/winch $20
I also have a M105 on 14.5's and A3 wheels that I can deliver if I get a buyer, see classifieds
And I'm sure I'll dig up some more stuff.
amgeneral72
126
HOLLY SPRINGS GA
Im bringing a semi full of all kinds of stuff.
pioneer racks and tools
antennas, mounts and bases
camo net
100 ft chains
water cans
fuel cans
jerry can holders
field desks
Hardig containers
and lots more
73m819
329
gainesville, ga.
We are looking for,
Right and left upper steering arms from a 809
Right front spring hanger pin from a 809/939
Steering wheel/column/upper steering shaft from a 809
Steel cross frame hyd. steering lines (2) from a 809/939
black out light assembly
CARNAC
The Envelope Please.
724
College Station, TX
I may have to bring in two loads of crap, I mean treasures. Any interest in
-flip up seats like I had last year
-395/85/R20 wheel assemblies with rims/runflats/used tires
-medium-heavy towbars (multiple sets with EITHER the 1.5 inch feet OR the Y feet with 3/4 and 1inch pins
-NOS (I think passenger side) deuce door assemblies with glass and hardware
-tiedown hardware as posted in my classifieds
-ISU 90 container
-Generator/ECU DRASH trailer as in the classifieds
-two M720 dollies (one had new tires put on 2 years ago and has zero miles) and S280 shelter (this 280 is the most pristine inside that I'd seen and I used it to camp in 3 years ago and has seen little use since). Was not originally planning to sell this. Will sell together and won't sell for less than I have into all three items together which is $2600. No I don't have pictures and no I can't get them. If you're serious about buying it, I can arrange for you to see it. If you're not real serious, go hump someone elses leg.
-two double sided expando shelters as described in the classifieds.
May have an M1101.
Looking for
BC620 (SCR 510) WWII jeep radio and/or any power supply and/or mounting brackets
M939A2 series wheel assembly with decent tire
Any WWII green iron that needs a new home
Replica WWII weapons to include US anti-tank mines and/or German Tellermines
WWII stuff that may look neat on a jeep, jeep trailer
Any of the stuff still showing as needed for my Common #1 and any vehicle specific support tools.
M151 stuff but not sure which model the one I'm getting is, should know soon.
I'll have to update this considerably as time approaches and depending on how much time I have to make 1 or 2 trips.
wreckerman893
Possum Connoisseur
15,647
2,141
I have seven HEMMET rims with o-rings and valve stems and the adapters to mount them on deuce axles. The adapters were CNC machined and are of fantastic quality.
I still have the M275 deuce tractor. It is in good physical condition but needs tires. The engine was running when parked but ran at high idle. I have a new in the box clutch that I'll throw in for free. I will only haul it to the rally if I have a committed buyer. I'm asking $4200.00 cash but I might trade for some cash and something I can't live without.
Update:
I'm making a tractor out of the M923A2 I bought a while back so I have a good drop side bed available. I'll bring it to the rally and either sell it outright or trade for something that don't eat.
If anyone is interested before the rally I'm asking 600 bucks you pick up at the farm.IMG_5561.jpgIMG_5562.jpgIMG_5559.jpgIMG_5560.jpg
Al Harvey
23
Dover, TN
I'm still inventorying what all I'm gonna bring this year but so far here is a short list of some NOS stuff.
900 Series Tie Rod Ends 4LH 4RH $50 each
1 set not in the box with some surface rust $50 for both SOLD juanprado
M35A3 and 900 Series Steering Wheels x3 NSN 2530-01-089-9129 $50 All SOLD CARNAC, GIMPYROBB, rebelqwes87
Vacuum to Electric Wiper Conversion Kits x2 $250 SOLD SCSG-G4x2
Generator Trailer Cover (M116 I believe) NSN 2540-00-926-0993 $400 SOLD timntrucks
Seat Cushions
IMG_2279.jpgIMG_2281.jpgNSN 2540-00-460-5815 $30 SOLD PATRACY
IMG_2283.jpgIMG_2282.jpgNSN Unknown $30
IMG_2294.jpgIMG_2295.jpgNSN 2540-01-153-8448 $20
Trailer Bow Corners
HMMWV Steering Gears x2 $400
M146 Window
M1008 Cargo Covers x2 $300
HMMWV Rear Cargo Cover $50
Vehicle Heater (I believe 900 series part number 12255989-1) $100
Axe Kits x 2 $200
There will be more as I finish going through it. I will continue to try and get some pics and prices up this afternoon.
5,221
Seat Cushions
Trailer Bow Corners
M146 Window
M1008 Cargo Covers
The seat cushions for a deuce driver seat?
