fuel issue? 83 am general m925 5 ton
2brothersjunkin
Kansas
Hello!
I have 83 am general, went to start it the other day fired right up. After it warmed up I climbes ito the cab and it shut down. Now it will not start. Turns over no problem just wont fire. Please help!
2brothersjunkin
Kansas
Did you pull the emergency shut off ?
If you did it needs to be reset manually on the injector pump.
After it didnt start we pulled it.to reset the switch you just flip it back right? I traced the shut off cable back to a gold, switch on the fuel system.Then we got a new fuel filter. Now when we prime it, its air no fuel from the hole on the bottom. As long as im priming it right.
HMMWV Nut
Forrest , Illinois
There's going to be a lot of air to purge out of the fuel filter canister if you didn't fill it all the way up with fuel, so it may take a little priming:popcorn:
Warthog
234
OKC, OK
Because they are on the website and need help. ;-)
Moved to the 5ton forum
2brothersjunkin
Kansas
Ok, now I have gotten it to prime, orings on the primer wereshot. But it stil wont fire. When fuel first started coming out it was dark, looked like it was mixed with oil. Then after a few pumps it came out clean. Still wont fire any more ideas?
goldneagle
1,112
Slidell, LA
Will it run with a squirt of ether? If so it might be air in the fuel line. There are threads in here already taht give step by step instructions on checking for air leaks in the fuel lines. Also could be a air leak in the filter housing. (Top bolt gasket)
2brothersjunkin
Kansas
yes, it will fire off ether. some of the fuel lines are cracked a bit gotta wait till monday to get new lines. any other thoughts? i thought it would just run rough with cracked fuel lines, not,not fire at all?
