5 ton Mack Turbo Diesel-Good Engine, Problems?
steelblue91
South Glens Falls N.Y.
Im looking into a early 1970's 5 ton (M39 so the owner says but im also told by others it a M54/M818), I haven't physically seen it yet to confirm the model but it has the Mack Turbo Diesel engine. Are these Mack Turbos a good engine? Any known problems & what are some things I should look at or look for if any? I have no idea if these engines have plenty of power or if they are junk. Any common problems with them & is there any articles in magazines etc written about these Mack Turbos? Thanks guys.
armytruck63
10
Redlands, CA
It is not an 800 series if it has the Mack engine, it would be the M54A1 type. The engine is very desirable for its longevity and wide power band. Unless the truck or engine is thrashed in some way, it sounds like a great find.
steelblue91
Thanks armytruck63! Going to view it so I know exactly what model it is for sure, owner says M39 while others are telling me different (M54?)
Evil Dr. Porkchop
272
Colchester, VT
The m54 is part of the m39 series of 5 tons. m54 is a cargo, m52 is a tractor, etc. The originals were gassers, the a1 series had mack engines, the a2 series had multifuels.
steelblue91
Ok-thanks! Its a tractor so it must be M52 is what people were saying it could actually be....with the Mack Turbo Diesel. I have no idea why people are questioning the model (M39 as the owner tells me it is). A friend of mine know's the owner & told me about this truck. So I called him out in western N.Y. & talked to him about it. Next is to go & see the rig! :)
steelblue91
As PC stated above M39s are a series of trucks. There are different versions of the trucks within the series
Deuces are M44 series
Early 5tons are M39 series
Mid 5tons are M809 series
Late 5tons are M939 series
http://olive-drab.com/od_mvg_www_deuce_m39.php
Thank you very much for the link! I noticed they have a M39 & a M52 listed....Im assuming that the M39 "cab & chassis" is just the cab & frame while the M52 "tractor" is the same with a 5th wheel hook up for towing trailers? Is that the difference between them?
jhooah
Carrollton/Virginia
You should find the frame and suspension beefed up in the tractor versions (and wreckers) the components for the most part are interchangable, but the frame and number of springs, possibly ratios are different depending on the mission of the truck.
The 809 series started with M52's, but were refitted with different engine and transmission (Cummings) and had a resulting longer hood and fender sheet metal added to them. the 800 series also changed other things like the dash, where emergency cutoff was added as well as changes in gauges.
It takes a little bit of studying to really get the vehicle lineage correct as far as gasser-diesel-upgraded diesel-change to diesel-change to drivetrain-change to vehicle layout goes.
Some drink fuel or smoke heavily and run slower (my M543A2 Wrecker for example crawls for a mile) than others, so don't fall in love with the one you'll learn to hate.
W Winget
