M101A2 Lug Nuts
KsM715
142
St George Ks
Are the rims you're installing steel or alum. ? If they are steel wheels then yes the original lug nuts will work. If they are alum. Wheels you'll need new lug nuts
dnote
Glen Burnie, MD
That is not what you asked in your post. Here is what you asked!
If the wheels are steel, the original lug nuts will work.
I was attempting to get across the fact that I'm replacing the stock steel rims with aftermarket rims and if the stock lug nuts would work. I didn't know that steel and aluminum rims require different lugs. The new rims are aluminum (Procomp 7089). Guess I'll be heading to autozone tomorrow.
