compression tester
rsh4364
15
greensprings ,ohio
Just ordered a kent moore J-26999-30 adapter for compression test on 6.2,any input on a comp. gauge that's compatible with this adaptor,if it tests good going turbo.
donalloy1
Martinez Ca
How well does it work? Need to check mine also! Found NOS J26999 compression gauge for under 30 you know where.
rsh4364
15
greensprings ,ohio
take your time, it would just be sitting on a shelf if it were here.
Got the test done a few weekends ago.Great to know I have very healthy motor! 395-405 per cylinder,and I installed oil pressure gauge and it carries 50-55 lbs.warm at idle.Used your gauge and adaptor and my set up also,both read the same.
TexAndy
15
Bee County, Texas
You could check compression quick and dirty with a digital oscilliscope. One that logs and graphs current draw over time.
Saw that on a car program. The ammeter function of the o-scope measures current of the starter motor. Just disconnect the fuel and crank the starter motor for a few seconds. As the compression builds in the cylinder, the starter motor draws more current.
I don't think it would give you an easy indication of which cylinder was the culprit, but it would be a quick way to determine if compression was an issue at all.
