Tornadogt
- 6
- 18
- Adkins, Texas
CSM Davis - You are correct about the intake caps. I removed what I thought was a different design to find it was only an additional screen as you described. Thanks for setting me straight.
Took the truck for a quick ride with the cap removed. No more sucking sound through the screen. That motor really pulls in the air when wound up (put your hand near the intake). Ill get some pressure measurements later.
There are some post on here where people have used scoops on the inlet tubes. I am not sure on the brand but they looked pretty good and are designed to add air flow and still not suck in water..
