No problem!
Since you have the thing already wired into the ignition at the fuse box, we'll use this to switch the relay. So, don't start your project by ripping this out!
But DO start your project by disconnecting your batteries!
Now, automotive relays have a numbering standard that makes life easier.
Any 20 or 30 amp automotive relay will do fine for this job. Just shop around to make sure you get one that is numbered, like
this guy. Oh, that's the first thing we need - a parts list.
Okay, here we go:
- Relay.
- Inline fuse holder, with a 10 or 15 amp fuse.
- 14 gauge wire. (Preferably red, since it will be a power lead.)
- 18 gauge wire. (Not red, and not black. Anything else is fine.)
- 18 gauge wire. (Black. This will be a ground connection.)
- Assorted electrical connectors.
Alright, we gots parts. Now, some assembly required!
- Find a good location for your relay. Preferably out of direct exposure to water. You can mount it now, or wait until you get everything hooked up.
- Run a 14 gauge wire from a solid power source (battery or the 12v block on the firewall) to the place where your relay will be, and from the relay location to the fuel pump.
- Run an 18 gauge wire from a switched hot location on your fuse block (your existing power feed will be just fine) to your relay location.
- Run a black 18 guage wire from a good, solid ground point to your relay location.
- Connect the black ground wire.
- Connect terminal 87 on the relay to your fuel pump using some of your 14ga. red wire.
- Connect terminal 30 on the relay to your good 12v power source lead (using some of your 14ga. red wire). Final hook up of power will be the last thing you do. (You can just take the fuse out and make all your connections.)
- Connect terminal 85 on the relay to your 18 ga. black ground wire.
- Connect terminal 86 on the relay to your 18 ga. switched power lead.
- (You can actually swap 85 and 85. It doesn't matter as long as switched 12v goes on one and a good ground goes on the other.)
- Verify your connections both for electrical integrity and to ensure you got it right:
- Relay Terminal 87 goes to fuel pump hot lead. 14 gauge red wire.
- Relay Terminal 30 goes to good 12v power source (but it's not completely hooked up yet). 14 gauge red wire.
- Relay Terminal 85 goes to ground. 18 gauge black wire.
- Relay Terminal 86 goes to switched 12v.
- If it all checks out, make the final 12v connection (put fuse in fuse holder).
Fire it up!
