M923a1 windshield washer system operation
gem1410
44
TOMS RIVER NJ 08527
When I operate the washer control and push it in all the way the top on the reservoir blows off--getting to much air pressure into the bottle-if I press it in 1/8 of an inch it works ok--is the control valve on the dash adjustable or is mine bad--thanks George
Artisan
228
CDA Idaho
Plastic Bottle Threads FUBAR (REPLACE)
Screw Down Lid Threads FUBAR (REPLACE)
Kink in outlet hose (UNKINK, POSSIBLE REPLACE)
Jets blocked (PULL, DE-CLOG FLUSH WHILE PULLED, REINSTALL)
Someone would have a real winner if they could find a GLASS bottle that simply swaps in.
That plastic pos jar is a pos. Maybe even a way w/ bulkhead barbs and use a new metal lid.
Doug Roberts
Chapel Hill, NC
The plastic bottle is mandated by
U.S. DEPARTMENT OF TRANSPORTATION
NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION
Part of the crumple zone for frontal impact
juanprado
3,139
Metairie/La (N'awlins)
I had the same issue. I replaced the washer dash switch and problem solved. Will /suprman has them in the classifieds
Alexsha
Cache Valley, UT
I hope I'm not hijacking, but I have a similar issue. With my m923a2, when I push the washer fluid button, instead of the lid blowing off, it some spray out the jets, but mostly, the resivior bottle whale blows fluid out the vent hose. Does this mean the jets are partially blocked?
