serpentine mudflap VHF antenna
olly hondro
545
tucson AZ
There is a company that makes them, embedded in mudflaps with an RF connector. I imagine one could come up with a poor man's version, sandwiched between two flaps. Your thoughts ?
olly hondro
545
tucson AZ
Green Wave Scientific. Will explore the patent offfice website to see what info is available. I like the idea of a stealthy antenna.
ke5eua
41
Baton Rouge (Central), LA
I love how it states 20-500 MHz but the vswr graph even shows anything below 90 MHz is over 3:1
I like the idea behind it but without a matching unit to accompany it your just melting the ice off the mudflap.
With the antenna so low to the ground the radiation pattern wouldn't be effective as a whip.
olly hondro
545
tucson AZ
My thoughts are along the lines of driving to the top of a hill then facing the rear of the vehicle toward where I want to communicate. Not on a regular basis, rather, for emergency or relay comms.
I am really am trying to keep the outside of my vehicle as clean as possible (no roof rack, fuel cans, uneccessary lighting) so do not want the antenna farm look. I guess I will just go with handhelds to solve that problem. I need mudflaps anyway, seems nice to have dual functionality wherever possible.
ke5eua
41
I understand the purpose, and need. True hams drill holes, lol
tim292stro
41
S.F. Bay Area/California
I tend to agree with Mike/KE5EUA. The radiation pattern they put in the datasheet is a free-space radiation pattern in a semi-anechoic chamber - not mounted to a vehicle, and definitely not mounted to a vehicle with your configuration (datasheets illustrate the ideal capabilities of the antenna before the "system" is considered). Vehicles make a terrible ground-plane due to the various body panels, rubber isolators, rust/corrosion, and the noise created by the vehicle's own electrical system - then take into account that the vehicle is mostly isolated from the ground by the tires making the truck a capacitive ground (virtual ground).
If you're already talking about parking your truck for emergency comms, why not get a telescoping fiberglass flagpole and hang a piece of wire from it and make yourself a dipole? The same pole could be used to make a ground plane antenna (4 ground radials). You can keep your radio in the truck if you want and put an N-connector bulkhead fitting somewhere out of sight (like in a rear fender-well) and keep a cover plug on it when not in use (further trick would be to put a dummy N-female connector with a micro-switch in the TX circuit of the radio - so you have to take off the cap, put in on the dummy fitting before you can transmit -should save a power stage or two).
If you just don't want it visible when you don't need it, try an NMO antenna mount through the roof, then put a cap on it when you don't have the whip attached.
