acesneights1
- 21
- 20
- CT
Well my Deuce has a bad vibration. It starts around 28 mph and peaks about 35 mph and is much better 40-45. It feels like a bad bearing somewhere. I was thinking ring and pinion on one of the diffs but then driving it today I noticed something. When I feel the vibration, I don't feel it in the shifter of the 5 spd main transmission but I feel it perfectly in the shifter of the transfer case. Engine rpms do not affect it. In fact I got it going around 35 down hill and slipped the Tcase into neutral and it was the same and I pulled the engine stop as well and still had the vibration. I have not pulled the drain plug on the T case yet. It's not undrivable, but very noticable. When you old the t case shift it vibrates ALOT. Anyone have this issue ? This could be difficult to nail down as it is not easy to put a Deuce on jack stands and run it up to 35 mph to try and find it. in fact that would probably be suicide.
If I don't find any metal in the t case drain I was thinking about pulling the front driveshaft.
