Military going from 9x20 bias split ring to 10r22.5 radial one piece wheels
juanprado
3,174
Metairie/La (N'awlins)
I noticed on a military train recently that the m149 water Buffalos had one piece wheels with radial 10r22.25 tires made by dunlop and Michelin on several other trailers.
I stumbled on the attached memo which I assume is from 2014 that over time with needed replacements, the split rim 9x20 bias will be unauthorized and replaced with radial one piece 10r22.5
Probably not coming to GL any time soon
gimpyrobb
dumpsterlandingfromorbit!
27,791
787
Cincy Ohio
I'm sure they will have the manufacture's name stamped in them. We just need someone to find out who it is...
Castle Bravo
Hundredaire Socialite
231
Arizona
Yeah, just look up the NSN -
Comes back as Accuride P/N 50434 or P/N 50434BLKCARC
2530-01-588-9171 Features
MRCParameterCharacteristics
AGAVEND Item Identification2330005423491
CDMCValve Hole ShapeLocate center of valve hole with center of hand hole within +-.7500
CXCYPart Name Assigned BY Controlling Agency22.5 X 7.5 accuride 15 degree tubeless steel wheel
FEATSpecial FeaturesBlkcarc is an accuride paint code refers to black topcoat paint finish
SPCLSpecial Test Features22.5 X 7.5 wheel, stud piloted, 6 hole, 8.75 inch bolt circle, 6.50 bore
STYLStyle DesignatorDrop center
SUPPSupplementary Features22.500 X 7.500 wheel assembly
agazza2
33
Ahwatukee, AZ
Accuride 6 bolt rim from 2011 Accuride Catalog
Great job looking this up Juanprado and Matt, also the in the 2011 Accuride catalog they show this information. On the website they only showed the 19.5 rim available when searching. Hayes rim may also be available at a reasonable price. Guess now I know an option for the M146 without swapping out the axle.
