Ok, here are some useful pics. You will see a picture of the area where the generator currently sits. This was the only logical place to put it in my yard. I wanted it obscured and had the uneven ground to contend with so I had to build a raised platform to allow storm water runoff to flow underneath. I knew I couldn't build a berm because I didn't want to dam up water in my backyard when we have the occasional downpour. The two hedges to the right of the 803 are going away to make room for the aux fuel tank. I'm building a platform of similar height, maybe higher for the tank.
in the other pics, you will see where I mounted my solar battery charger. Inside one door, you will see my added country boy ASK in the form of Dow foam board. On the inside of the top panel and throughout the generator, there are pieces of asphalt sound deadening mat. I used the "GT Mat" sold on eBay which cost me about $40 for a four door kit. The Dow foam board I had laying around. I spray glued the foam board to the doors.
In another picture you will see where I wired my instrument lights up. Since we are not in a combat environment, white light is much needed over the dim green lights. I took one length of wire and picked up switched power at DS1 and hit the light bulbs that were already installed. This was a five minute mod.
More pics will come...
