jamasonodom
- 0
- 1
- lyons / ga
Air brakes are miles ahead of the stock air-assisted hyd system. The main thing is no more brake fluid leaks. You can still have air leaks but it's not as messy as fluid leaks and you're not as likely to run out of air because the compressor is always making more. Adjustment is much easier for s-cam brakes (the same can't be said for the 5-ton wedge brakes). Also, no more leaking, malfunctioning master cylinder or airpack.I will say you have certainly put some effort in that. What was the need?? Or just something you wanted to do? Interesting looking with the brake shoe sticking out the back of the drum 3/4".
While a air drier would be nice, it's not a necessity. There are plenty of air brake trucks on the road without air dryers and they do just fine (you just have to drain your tanks every day).A couple of things need mentioning about converting to air-brakes. One, you will need more and larger air tanks (at least 2 ). Two, you will need R-14 valves for each axle. Three, you will need several one-way check valves in the system. Four, you will need an air dryer like the Bendix AD-9 or the Haldex PureAir . Five, you will need an application valve ( brake valve) and it will need to be sized to the rig. Six, you will need a new air-compressor. One that has a higher CFM rating and longer duty cycle . These are just the start of what you will need to convert to an all air-brake system. The cost will be considerable.
As far as the air-dryer goes, according to Federal regulations you either have an air-dryer or as "Birdman" mentioned an "methanol injection" system. As far as the air compressor goes, it probably does meet the minimum CFM requirement but it does not have the "duty cycle" needed for a total air system. Bendix has copious amounts of documents for download explaining all this. Personally I would love it if the deuce came with air-brakes. I have worked on these systems for decades, and have quite a lot of spare parts squirreled away, ie: R-14 rebuild kits, one-way check valves, dump valves, AD-9 rebuild kits etc. I know though what it would take to make a deuce into a complete air-brake system and the money needed to make it Federally compliant. These last few years at Metro Transit I have been the Inspector for the busses. Every 6 months I had to go to class and recertify to be compliant with Federal Law. I have manuals on what is legal and what is not. Brakes are the number "1" issue that the Feds are most anal about, and if you mess with them and they no longer meet requirements then your truck is booted off the road period. So saying all that, if anyone wants to go ahead with converting to an all air brake system I say "go for it" . I would love to see ! Then maybe in the future I will attempt it.While a air drier would be nice, it's not a necessity. There are plenty of air brake trucks on the road without air dryers and they do just fine (you just have to drain your tanks every day).
I also think you could probably get by ok with the stock air compressor. Only testing of the system would tell for sure but the stock compressor is comparable to what older civilian air brake trucks use.
Good points on all the rest.
I would also caution the OP on making these kits for resell. Designing complete brake systems from the ground up and selling them has lawsuit written all over it. I'm not saying don't do it and I may be interested in a kit myself but just know what kind of liability your exposing yourself to.
I would love to see the regulation that says a air dryer or methanol injector is required. There are thousands of civilian trucks on the road than never came with either system from the factory. I've personally got a 1983 Freightliner that doesn't have a dryer or injector and has been federally inspected and there was no mention of a brake violation. I've also looked through the federal standards (FMVSS 121) and see no mention of a air dryer or methanol injector being required.As far as the air-dryer goes, according to Federal regulations you either have an air-dryer or as "Birdman" mentioned an "methanol injection" system.
I'm talking about 2014 not early models grandfathered in. If you complete this project in 2014 you will be required to meet 2014 standards. Go and talk with any State Patrol inspection station, you will soon find out what is required.I would love to see the regulation that says a air dryer or methanol injector is required. There are thousands of civilian trucks on the road than never came with either system from the factory. I've personally got a 1983 Freightliner that doesn't have a dryer or injector and has been federally inspected and there was no mention of a brake violation. I've also looked through the federal standards (FMVSS 121) and see no mention of a air dryer or methanol injector being required.
I'm not saying I'm 100% right on this but just going by the shear numbers of trucks on the road today without air dryers (most all older trucks unless one has been retrofitted) and the fact that I haven't been able to find it in the regs, I tend to think, although a air dyer is a good addition to any system, it's not a requirement.
