USSC 9110 Seats in M923A2
brasco
Southeast of Indianapolis, In
I'm planning to install a set of USSC 9110 seats in my M923A2 and I would like to see pictures of other installations before I start.
So.... If you have installed them in your M939 series would you please post pictures here. If you have any advice to share on installation then I'm happy to listen.
The seats I have are tan but would like to have green. Does anyone know a suppplier for a good fitting seat covers that are OD green or black.
Thanks,
Don
D
Deleted member 11142
Guest
brasco
Say goodbye to your leg room.
Thanks for the pics and your feedback. Can you tell me how much further forward these sit? I know there is not much leg room using the stardard seats either. I sat in a frankencab once that had these seats but didn't notice a huge problem at the time. I am about 5'10" so maybe less of a problem than taller people.
Ddmk18
James Creek PA
I got new replacement seat covers from USSC talk to mark in military department. They weren't near as expensive as you would think it's just a pain to recover them.
Suprman
707
Stratford/Connecticut
I think I have more legroom with them. I took out my original seat and sliced off the base plate. Bolted the plate back in, put the seat in and lined it up exactly where I wanted it. Marked it on the plate took it all out, welded seat to plate and bolted it right in.
brasco
I'm thinking about something similar. I really haven't looked at the details yet but plan to fabricate a plate to use the old holes if possible. The passenger side may need new holes drilled anyway and I'm not sure what I will run into once I pull the battery box out.
I have a set of 4 drivers side seats but I have seen passenger side seats for sale on GL. Do you know if they can be easily converted using existing parts or do they use different LH and RH parts. I guess I could always trade with someone who had the passenger seats I really wanted RH and LH seatbelts.
Suprman
707
Air ride is adjustable via a small air in-out control. Everything else is knobs. Very easy to adjust and the seats are very durable.
