hoplite666
- 1
- 18
- Fairfax VA
Did the spin on fuel filter mod today.
Ill start by saying that everything you need to know about doing this mod can very easily be found by using the search feature and taking some time to sort through the various parts lists other members have provided.
I ended up totally hijacking the design and parts used by several of the guys here. Thanks for that!
With that being said, I still found myself walking up and down the aisles of Home Depot trying to find the appropriate fittings. I figured Id post some picks of the packaging of what I ended up buying for you guys that have not yet done this mod and are thinking about it.
After some thought I ended up ordering the Napa fuel filter base #4770. This base apparently has more filter options. (according to other users)
These are the fittings I bought. They allow you to reduce down from the 1/2 inch holes on the base back down to the 3/8 and 1/4 inch fuel lines.
And here it is all plumbed up
This particular filter set up did require that I make a small riser which I bolted to the existing mounting bracket (used some thin galvanized steel from Home Depot) to avoid clearance issues with the bottom of the filter and the valve cover. (same as other members)
