I was brining my analyzer and meters but due to truck issues and my persistence to get it fixed I'm not making the rally at all.
If the antenna is 1/4 wave length should be 18"
1/2 wave 36"
3/4 wave 54"
4/4 full wave 72"
Side note, a 6 meter / cb 1/4 whip can be used on 2 meters in a pinch.
I go by the 18" rule and it doesn't fail when making a quick antenna.
If you have access to an ohm meter take the antenna off the base and verify at the 259 connector that the center pin and ground is infinite. Also you could ohm out the center pin to the center of the base of the mount and if it is over 50 ohm then you have an issue with your cable. Some ohm meters won't show 50 ohms I've noticed when checking cable integrity.
