If you've followed my other posts I had a starting issue with MEP802. I had no power going to the starting relay. I tried absolutely everything could not find the problem. Well yesterday I spent all day and I found the problem I guess is happened from vibration I also found another wire on the ballast resistor was broken. Generator starts up it works great!!! Ran it for about an hour then noticed my load meter stopped working... Grrrr always seems to be something.![ImageUploadedByTapatalk1401831838.896425.jpg ImageUploadedByTapatalk1401831838.896425.jpg](https://www.steelsoldiers.com/data/attachments/338/338606-106a106354aa746e489f95d159752165.jpg)
