- 3,243
- 445
- 83
- Tonopah, AZ
I have had my M35A2 for about 5 years now and it has always ran great. The problem I have with it is that when you try to start it you have to turn it over a longer then my other trucks and when it starts it runs rough for about 5 seconds then it is fine.
After it is started and ran a little you can stop it and restart it and it starts right and runs fine. But if you let it sit for a day or so and start it, it will run rough for about 5 seconds and then it is fine.
I would like to get the fixed and I was thinking it maybe leaking prime from one or two of the cylinders.
Should I start with pulling the injectors and have them checked or do you think it is the IP pump or the hydraulic head?
I do turn on the main power and let the pump run a little before I try to start it.
