rory1919
- 0
- 6
- morrow ohio
So i've searched through the forums but ive not found what im looking for. ive read through some of the TMs and not found what im looking for but maybe im just missing what to look for.
I have driven larger truck with air brakes in the past but never had to do any maintenance on them.
i drove my 5 ton home form indianapolis with no issue. everything seemed to work like a dream. halfway through the trip the CTIS lights started all flashing instead of being one button selectable. one of the tires has a leak and the CTIS still worked to inflate that tire after the fact.
ok so here we are 3 weeks later and i need to move the truck. the bad tire is up on jack stands to reduce and pressure or future damage to the tire. So i start the truck and let the ctis inflate the tire again. all is fine. I remove the jack stands. but the truck now won't move. the brakes are locked up. I moved the truck a bit to see if one tire was locked up and others free (looking for a skid mark in the grass) not sure of this would even work but made sense in my novice brain. this did not show any difference. and for how much resistance there is, i couldn't imagine that it is only one wheel.
the air system is burping extra gas out like i am hitting the brakes every few minutes.
oh yeah both air tanks hold steady at 100 psi. (seems like most brake issues listed here have issues related to the air pressure)
emergency brake is down and i never engaged it.
brake override knob is pulled out in the normal position.
any suggestions? am i just a dummy and am missing something normal and simple?
Rory
Rory
