04mustang
- 10
- 18
- Lumberton/NC
ok, so ive read plenty of other posts about oil pressure related problems with these trucks, but im not sure mine is an issue yet. looking for help from other people with more experience than me here.
I drove my truck to work one night this past week and watched the gauges the whole trip, about 10 miles. everything looked good. On the way home, 8 hours later, it had low pressure at start up around 5 psi or less. and at speed it had 15-20 psi the entire way home. my guage is a 0-60 type, everything same a militaty, not changed.
I did a little record experiment the next day after letting it sit for about 12-14 hours. the following are my results:
at start up, cold
- 15 PSI @ idel
- 30 PSI @ 1600 RPM
after 10 mins, 120 degrees
- 14 PSI @idel
- 25 PSI @ 2000 RPM
after 15 mins, 130 degrees
- 20 PSI @ idel
- 30 PSI @ 2000 RPM
after 20 mins, 140 degrees
- 19 PSI @ idel
- 28 PSI @ 2000 RMP
after 25 mins, 160 degrees
- 12 PSI @ idel
- 20 PSI @ 2000 RPM
after 30 mins, 170 degrees
- 5 PSI @ idel
- 22 PSI @ 2000 RPM
after 35 mins, 170 degrees
- 10 PSI @idel
- 22 PSI @ 2000 RPM
The other part of this is a fuel leak as you can see from the photo below. Its somewhere above the the oil filters. haven't traced it down yet.
so are these 2 issues related and is the oil pressure an issue at all or am I just being too cautious?
Thank you,
Corey
at start up, cold
- 15 PSI @ idel
- 30 PSI @ 1600 RPM
- 14 PSI @idel
- 25 PSI @ 2000 RPM
- 20 PSI @ idel
- 30 PSI @ 2000 RPM
- 19 PSI @ idel
- 28 PSI @ 2000 RMP
- 12 PSI @ idel
- 20 PSI @ 2000 RPM
- 5 PSI @ idel
- 22 PSI @ 2000 RPM
- 10 PSI @idel
- 22 PSI @ 2000 RPM
Thank you,
Corey
