trooper632
- 3
- 18
- Utopia, TX
Hey all, New mep-002a read what I could on it before trying to start it, new oil/fuel filters reconditioned batteries installed do all the priming both pumps work getting fuel to the IP but nothing out of the injector lines. Two questions. #1 when it cranks but wont start the issue there is, when I let off the start switch it still keeps cranking. I had to remove the positive battery cable to stop it. I hit the starter a couple of times with a mallet and tried it three more time that way but the starter sticks on every time. Is the solenoid bad/starter bad or something else I might be missing. and #2 the fuel issue at the IP, I have read several posts about that one but hope some one could chime in before I have to search again the best way to attack that one. The oil pressure does start to build while cranking also, thanks
