Randyw
- 6
- 18
- Bridge City Tx.
I have an 84 1008 that I had a 6" rough country lift put on about 2 years ago. I am running 37 Humvee rims and tires on the truck. Last night my son got the truck in a pretty bad hole and sheered 3 out of 4 studs on the king pin steering arm cap. I noticed that the lift has a spacer block to raise the steering arm which has the 4 or 5" studs in it. These were the studs that sheered off. So I have a few questions for you guys that are running lifts. 1. how do you get the broken studs out of the king pin assembly? 2. Is there a fix for this? it is obviously a weak point. would it be better to go with a dropped pitman arm and do away with the king pin spacer block or is there anything else I should do?
