ShaggyTheGreat
- 1
- 0
- california
Recently tried to start my gas generator, not military but I figure you guys can help anyway. I started it with the choke on and then flipped over to run and it hunts rpm violently. Basically from an idea to full speed back to idle. I then took the choke and put it on about 90% and it clears right up. Put the choke all the way on it acts like it always does when you put the choke on all the way. Low rpm running crappy. I took off the carb and cleaned all the Jets. Put it back on still same thing. I haven't touched the adjuster screws so I'm kinda out of ideas. I let it run for a while and it didn't clear up.
