gimpyrobb
dumpsterlandingfromorbit!
- 27,785
- 749
- Cincy Ohio
Not all riveted rims have the 1" offset, so no.Those are the riveted rims right?
yes but i have seen a lot of them welded because i think the rivets came loose.Those are the riveted rims right?
If you sight down the outside edge of the tire, the center of the rim is ~flush with the edge of the tire on the M135 rim. The M35 rim centers stick out.Alright. So how do I tell the 135 rims from all the rest so that I know when I get my power steering kit from Tom?
I did adjust the R.H. stop a bit previously. Maybe I'll just turn it out a bit more. Or I may look for some m135 rims. Are they hard to come by? Thanks Tom!no, that is normal and really depends on wheel offset. there are now so many wheels used other than stock, but the solution is to adjust the right steering stop a little. you really don't loose much so you will not notice it. i used m135 wheels on mine as they have 1 inch more offset so it clears by an inch.
They are a dime-a-dozen, till you want one.I did adjust the R.H. stop a bit previously. Maybe I'll just turn it out a bit more. Or I may look for some m135 rims. Are they hard to come by? Thanks Tom!
