S250 floor strength?
Csm Davis
406
Hattiesburg, Mississippi
What is the S250 floor strength if it is not supported from underneath? I am wanting to put one in a bed that it will ride on the sides not the floor or will I need to support it underneath?
SCSG-G4
PSVB 3003
5,400
3,493
Lexington, South Carolina
Well, the lifting rings in the top corners are supposed to be able to handle the max filled weight of an S-250, so I don't see why the outer side (bottom corners) would not be able to do the same. Wouldn't hurt to put a rail underneath the outside edges of the floor just in case.
MWMULES
352
DESOTO, KANSAS
When they were carried in a m880 they had dunnage (wood) under them so they didn't ride on the bed sides.
