AXLES
Front - Rear = UHDPX41
Rear - Rear = UHR
Yesterday I wrote Meritor and requested AXLE poop. I received
a reply this morning along w/ several PDF's. Here is the message
that was in the reply to me from Meritor;
"The UHD axle is on old one. There is no catalogue for it. I have attached the BOM,
however, which shows the 6.17 gearset ratio. Make sure that is what your ratio is.
It should also be on the UHDPX41 axle tag. The rear-rear has its own tag #, UHR….. .
I have also attached exploded views and parts list for the UHD and UHR carriers .
You would use the actual BOM for UHDPX41 for the forward carrier parts, even
though you see the drive carrier parts on the exploded views and parts list also.
There is some variation as you might see—the BOM takes precedence for the part #’s..
To see our online catalogues sight for searching for maintenance/service manuals :
http://www.meritorpartsonline.com
Click Literature on Demand at the bottom of the home page
Choose Axles and follow the directives for finding something.
You might have to download maintenance manuals (MM5 series for drive axle carriers)
to see which carriers are covered, for example UHD, UHR)"
CLICK HERE UHDPX41
CLICK HERE UHD
CLICK HERE UHR
Front Axle =
FDS1807RSA11 AXLE ASSEMBLY
or
FDS1807RSA-50 AXLE ASSEMLBYAUTOM (WET)
Crap, how do we tell the difference between the ...A11 AND TEH ...A50 "WET" ?
My FRONT axle Tag (BELOW) is almost gone.
![front-tag.jpg front-tag.jpg](https://www.steelsoldiers.com/data/attachments/361/361578-cfac7f8080a7020e19b9e32ae8f88a89.jpg)
Here are the files for the front;
CLICK HERE EXPLODED
CLICK HERE BOM ...A11
CLICK HERE BOM ...A50
My FRONT-REAR axle Tag (BELOW) I ASSUME THE GEARS ARE 6:17 ;
![rear-front-tag.jpg rear-front-tag.jpg](https://www.steelsoldiers.com/data/attachments/361/361579-f9e77a31c82ffa9671cf4ee5e3beb4ce.jpg)
FRONT AXLE ADDENDUM;
OK the data plate, 2 pics above, this is actually the axle HOUSING data plate, not the AXLE ASSEMBLY data plate.
The axle HOUSING Data plate is on the front of the DS arm, the axle ASSEMBLY plate is
on the same arm on the BACK of the axle arm. My data assembly plate below shows "I" have a
FDS1807RSA11 AXLE ASSEMBLY.
![front-tag-assembly.jpg front-tag-assembly.jpg](https://www.steelsoldiers.com/data/attachments/361/361600-79fa92058b3bbc74e68f9c47fbe73805.jpg)
( I still wonder what a FDS1807RSA-50 WET axle is now ! ! ! )
EDIT:
I wrote Meritor and asked them about the two front axles the TM says the M916 could have,
here is the conversation starting w/ my questions;
...can you tell us the basic differences between these two axles please?
My TM says my trucks could have had either axle I do believe.
FDS1807RSA11 AXLE ASSEMBLY (My truck has this axle)
or
We are assuming that the only difference is how the bearings are lubed, where
my FDS1807RSA11 we think uses grease and the FDS1807RSA-50 uses oil???
Can we assume that both units will have the same gear ratio by these numbers?
Meritors reply;
The spec numbers have nothing to do with whether they are wet or dry. Seal types might. But the brakes and wheel end group are the same on these axles. The brakes have a 2 degree difference on the brake angle mount. The carrier assembly in the RSA50 is a later version than the RSA11 carrier.
The axle housings are different
Cross tubes are different.
snip
The gear ratios would have to be at the end of the assembly numbers and become part of the assembly #. These BOM’s can show multiple ratios, but in this case the only ratio showing in the BOM’s for both is 6.17. That does not guarantee, however, that this is the only possible ratio these might have been made with.
END
Rear - Rear = UHR
CLICK HERE UHDPX41
CLICK HERE UHD
CLICK HERE UHR
Front Axle =
or
CLICK HERE EXPLODED
EDIT:
or
Meritors reply;
snip
END
