- 179
- 19
- 28
- Gilroy, CA
Racked up a bunch of miles on my 923a2 converted into a 931 over the last year, but recently have ran into some issues with the air system.
Started off with a bad head gasket that I replaced, and a thousand miles later it looked like this:
Fixed that, but had it fail two more times since.
Installed a new air dryer, unloader valve, and governor. Still had a head gasket fail. Finally just swapped the compressor out of another truck, and that has been fine for the last 500 miles or so. Hoping that solves that issue...
Somewhere in the midst of all this, I noticed the secondary air gauge reading about 10 PSI lower than the primary. No obvious air leaks anywhere, and am in the process of troubleshooting, but wonder if the two are somehow connected?
The only other odd thing to ever happen was the parking brake failing to release. Truck sat outside in 30* weather for a few days, think it caused the valve under the drivers door step to freeze up. Brake eventually released on its own, and has been fine ever since.
Washed the truck today, and will be going through it tomorrow with the TM. Any ideas?
