Glockfan
- 13
- 18
- Brigham City, Utah
Are you connecting an MEP or a commercial genset to your house? If you are going to use an MEP, the connection should be made at the terminal lugs on the generator.Great all around set up. I'm going to do the same with mine but until then it will remain "mobile". When I built my place I had the electrician put an outside RV type plug and a manual transfer switch in the main panel. I have a 50 amp 6/4 wire generator cable that will plug into the external plug at house. If I cut the other end off, how would I connect it at the generator? After seeing your set up I think I should have had the outside transfer put in instead of the switch at the main. And of course the huge question is when to ground and not to ground the gen.
I think there is little noticeable difference in the noise between the 802 and 803. I ran an 802 for five straight days powering my house on just over 5 gallons a day. I dumped one fuel can per day in the 802 and never shut it down for a minute during our ice storm back in Feb of last year. I'm not sure what the 803 consumption would be but I'd bet not more than 10 gallons a day at 1/2 load. 802's are getting cheaper now. If you play your cards right, you may be able to get into one with less than 2500 hours on it for around $1500-$2000.Trying to decide between MEP-802A and MEP-803A and have some questions since you had both.
1- Is the 802A louder than the 803A or about the same?
2- I know the full load fuel consumption but do you know the 1/2 load consumption of both? Especially interested in the 803A 1/2 load consumption because 1 gal/hr is more than I would want to use but I like having some reserve power.
3- what is fair price for decent shape 802A with 2500hrs?
Good Lord! That's crazy... $4k for a month of power, I'd rather check in to a Hotel somewhere...Speaking about fuel consumption, I had been looking at automatic LP gensets and the consumption must be terrible for even a 12kw system because someone had posted in reviews that he had a 1000 gal LP tank that would last him a month if necessary. That is an expensive month with LP near $4 per gallon !!
Prior to me going the MEP route, I always thought the supply of natural gas would never really be disrupted. You learn a lot here. I never considered compressors used to boost the NG supply to my home. Now it looks like diesel is the way to go for long term storage and efficiency and true reliability. I know I can run at least 10 days on my supply. I've debated on filling about ten cans and storing them off site for real emergencies. It wouldn't be too difficult to drive a couple of miles to my storage unit for another 50 gallons of diesel.What makes it worse is that NG/LPG doesn't do well cold, it can freeze the tank as it expands. If you've piped your genny into the local gas supply, and there is a huge power disruption, the booster compressors that the gas company uses to deliver NG can also fail meaning that you won't have fuel (so a local accumulator tank before the pressure reducing regulator is a good idea, but hard to get okay'd).
Nothing really beats diesel for reliability, unless you have a stream/river, ocean, windy location, or your own nuclear reactor...
great article!Not a hidden problem, but not a frequently publicized problem.
http://www.forbes.com/sites/peterde...-grid-at-its-worst-how-about-the-gas-network/
Or if you want to get really serious, perhaps a some 55Galon drums? With oil prices where they are right now, it's probably a good time to do the cash outlay for the first fill-up. Keep it circulated by using it in vehicles (if you have diesel vehicles) or your generator (to replace what you use during your genny exercise cycle)....I've debated on filling about ten cans and storing them off site for real emergencies. It wouldn't be too difficult to drive a couple of miles to my storage unit for another 50 gallons of diesel...
