Manuals needed for Ingersoll Rand MC 2A air compressor.
R Racing
St. Leonard, MD
Well I have 1. Not alot to them. If it's cold out use the glow plugs. Push the start button to turn the engine over. There are 2 valves. 1 adjusts the output. The other if I remember right causes it to load and unload value. There Great little unit !!! Mine has been fantastic! Would love a paper manual.
R Racing
St. Leonard, MD
I use it as a backup for my shop. I have a German screw compressor that can take several days to get parts if something brakes. the main shop compressor has high hrs. So I thought it would be a nice backup unit . I have also used it to pump up tires on my trucks . It does it alot faster than using the truck itself.
RJM27
30
Burdett NY
It is the Davey 7MC-2a rated for 15cfm-200psi. I see you live in MD. Upstate NY. will be headed to Fort Meade next friday 2-6-15 have 11am pick up apt. Any suggestions for getting in and out of base, been several years since I was down there. Will be leaving from my son's house in Carlisle PA>
Thanks. Bob
MWMULES
349
DESOTO, KANSAS
It will work on a 125 pound pot with the smaller nozzle if the vanes are up to snuff.
RJM27 they are heavy and wider than they look and would not fit between the wheel wells of my 1T, tow speed on them is 25MPH.
RJM27
30
Burdett NY
Copy that, will be hauling it home on trailer. How is the recovery rate when sand blasting?
MWMULES
349
DESOTO, KANSAS
Mine did ok with a 1/8" Nozzle it's the IR version but if you want to do something big rent a bigger unit and pot or hire it out.
JILY
Indiana
Here is a link to the MC-2A compressor manual. TO 34Y1-87-61.
This is a type RR-15 Ingersoll Rand sliding vane compressor it uses SAE 10W oil in the compressor.
This link has been removed due to the fact that the TM is not released to the public.
Naviator
Phoenix
I also need the manual for the Davey MC-2A rotary air compressor but mine as the Lycoming engine,also sent an email to Davey Compressor still waiting for an answer from them will post the reply ,,
