- 1,614
- 694
- Central NY
Zebedee in answer to your question our m62 does not have that bar..but does have holmes gear on the rear. it's not referred to as a speader bar but it does the same job seemingly and is lubed by oil can. there bieng no grease nipples. you can see our gear in the post on this thread somewhere.
We are kind'a sort'a speaking the same language! You do have the "spreader bar" that I am refering to - just call it something else I'm guessing - see your pic and the circled notes....
![dmetalmiki.jpg dmetalmiki.jpg](https://www.steelsoldiers.com/data/attachments/323/323478-199a04e162ab69edab53743bdc1a9afc.jpg)
I captioned the pic for future reference with regards the "Holmes gear" and it's usuall use - ie., without the secondary 'setup' underneath.
Oil can lube seems appropriate for the collar that holds the spreader tube. Maybe yours was once welded and painted over...
