I noticed that the left turn dash lamp was on when I pulled my headlights on. I posted about this before, and read threads on it that others had started. For no conscious reason I wiggled the turn signal lever and flipped the hi-beams on... some wehere in there the left turn lamp normalized and went out.
Is this likely to be ignition switch (above column), or turn signal cancelling cam related; you know, bad ground?
